dash frame around radio....
....peeling up. I've searched and could not find anything related....anyone have any advice on what type of adhesive I might use to keep this thing in place?
I've tried some very strong glue and also I've tried double-stick tape, no good. Any input is welcome! I know I know....it isn't Blaupunkt. PO did that one. http://forums.pelicanparts.com/uploa...1337525505.jpg |
Same thing happened to mine. If you think you can salvage (mine needed to be replaced) try 3M trim adhesive. Be careful not to get on the face of your dash - hard to get off. Stuff works great. Good luck!
thanks seg....do you happen to recall the part# or the description you used to find this part? I've been unable to find it.
| All times are GMT -8. The time now is 05:11 PM. |
