marcesq's Avatar
Quick Turbo Tie Rod ??
I'm in the middle of this and I want make sure that I am to disgard part number 2 on the attached.
As soon as someone is kind enough to confirm this, I will finish up and call it an evening.
As always thanks in advance.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 05-08-2002, 06:52 PM
no you would not use #2. the item 13/2 does not come in the kit. i've never seen a nut there. there's supposed to be a thick spacer/washer there, between the rack shaft and the tierod joint. silicone spray on the rubber boot ends helps a lot.
206 637 4071
Old 05-08-2002, 07:10 PM
marcesq's Avatar
Thanks John.
My kit has the thick washer rather than the nut.
Now I can get back to it.
Marc
Old 05-08-2002, 07:14 PM
