Tim Boyer's Avatar
Fuel pressure/fuel filter question
Hi,
I am installing a PMO fuel pressure regulator. Do you put the fuel filters before the gauge or after-on the way to the carbs?
Thanks,
Tim
Old 05-21-2012, 02:33 PM
76 911S Targa
Tim,
I presume you want to know what pressure your carbs are seeing so that you will know if you are exceeding or meeting a certain pressure spec? I would put the gauge so you know what you want to know, namely the pressure at the carbs, and therefore after the fuel filter. Ah, I see you asked where to put the fuel filter. Put it before the gauge. That's my opinion.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 05-21-2012, 03:10 PM
