-   -   Right Turn Blinker on Dash Stopped Working (http://forums.pelicanparts.com/porsche-911-technical-forum/679275-right-turn-blinker-dash-stopped-working.html)
szyzygy 05-21-2012 06:57 PM
I noticed I was driving around a bit today with my right turn signal on after switching lanes, and it didn't self shut-off. That's not like me. Then I noticed it was because the flashing light wasn't there to remind me.
The exterior turn signals all work, and the left blinker on the dash works.
Hazards all work, too, but they don't cause the dash blinkers to flash. Seems like most other cars I've owned, the hazards affect the interior flashers as well.
So what do you guys think is the issue? Bulb? Loose wire? There wouldn't be a separate relay for each blinker light, would there?
TIA
DRACO A5OG 05-21-2012 07:42 PM
Pull the gauge and check the bulb, swap to check it is not the socket or wiring. Probably jusy the bulb. don't sweat it.
Dosconnect the battery when you do, just incase the hot lead hit the chassis. Also best to pull the clock then speedo, reach in behind it and push the Tach out.
Dublinoh 05-21-2012 08:02 PM
Tack is the tough one, need to remove steering wheel and clam shell.
szyzygy 05-22-2012 07:09 AM
Thanks guys. I'll check the bulb. if theres one thing I'm good at, it's removing the wheel!
Wish I knew the bulb was bad earlier yesterday....just ordered a bunch of stuff from our sponsor.
Joe Bob 05-22-2012 08:02 AM
I've pulled the speedo, reached in and got the bulb in question out....lot easier.
vwporschegt3 05-22-2012 10:53 AM
did you check your blinker fluid? http://forums.pelicanparts.com/support/smileys/lol2.gif sorry couldn't help it SmileWavy
szyzygy 06-04-2012 07:00 PM
I pulled out the tach to the right and reach in around the back of the speedo. I felt a hole where the plastic cap should rest. Closer inspection revealed that the plastic housing & bulb had simply fallen out behind. I put the key in the ignition, and used my turn signal. There is was, flashing away. I plugged it back in and back to normal.
Thanks everyone. Glad I didn't even have to take the wheel off using the ole' tach trick!
