-   -   Pulls To Right When Power Is Applied (http://forums.pelicanparts.com/porsche-911-technical-forum/679484-pulls-right-when-power-applied.html)
dkirk 05-22-2012 07:32 PM
Just when I thought my '88 was all sorted out, I'm now realizing that it wants to go (very slightly) to the right when power is applied. This is especially noticeable when on a smooth, lightly crowned road, in 3rd gear, engine turning around 3000 rpm, and full throttle is applied. Car just nudges slightly to the right, requiring a couple of degrees of left steering wheel input to remain straight. When throttle is closed (for the next gear), car will then nudge to the left.
My prognosis is as follows:
1) Rear spring plate bushings need replacing
2) Rear trailing arm bushings need replacing
3) All of the above, as they're all original
Has anyone experienced this and what were the offending parts that needed replacing?
http://forums.pelicanparts.com/uploa...1337743797.jpg
rickybbear 05-22-2012 08:18 PM
has it been aligned recently? I guess# 2
Noah930 05-22-2012 11:10 PM
Are all 4 tires fully aired up?
rnln 05-23-2012 01:31 AM
- right rear is toe in a little more than left wheel?
- one of the right brake caliber is slightly stuck?
fastfredracing 05-23-2012 03:03 AM
Wheel bearing with some play in it.
BK911 05-23-2012 04:02 AM
Check your thrust angle.
Attach a string to the back of your rear tire and stretch to a jack stand in front of the car.
Move the jack stand until the string barely touches the front of the rear tire.
Measure distance from string to center cap of front tire.
Repeat on other side.
Measurements should be VERY close.
Quick alignment check.
hcoles 05-23-2012 05:43 AM
Thanks, never thought of that. Quick/easy.
5String43 05-23-2012 06:09 AM
An alignment issue?
rsscotty 05-23-2012 06:43 AM
I have seen this before...the alignment was good. It ended up having the corner weights way off. After re-indexing the left rear torsion bar to get the weights where they should be everything was fine.
HelmetHead 05-23-2012 07:10 AM
Do you hear any growling noises at high speeds (+100)? You may have a rear axle bearing going out.
hcoles 05-23-2012 07:52 AM
a proposed alternate to testing at 100, jack up one side at at time place wood dowel or auto stethoscope on arm at hub and spin wheel, might give an indication of bearing condition especially if both sides sound significantly different, can also try cocking the wheel to see if any play
dkirk 05-23-2012 12:06 PM
Thanks guys, for all the great suggestions. The following has been ruled out:
Tire pressure - 29 psi front, 36 psi rear, both sides equal
No dragging brakes
Front end is aligned to spec
Corner balanced with side-to-side weights being very close
Could possibly be a wheel bearing. I hear a change in sound quality when off vs. on the throttle. Will perform the stethescope test plus wheel cocking test.
Rear wheel alignment was performed during set-up several years ago. Probably worth doing the string test again just to check.
She's going on the rack tomorrow and I'll let you know what I find.
hcoles 05-23-2012 01:04 PM
something just occurred to me... what if a brake pad got contaminated or ? somehow became different than the others, easy to pull and look, clean and reinstall
tharbert 05-23-2012 01:07 PM
"slightly crowned road" ???
calling911 05-23-2012 01:26 PM
I wanna know the answer to this...
911pcars 05-23-2012 01:50 PM
"Corner balanced with side-to-side weights being very close"
How close? Road-going 911s have a driver and a battery not symmetrically located.
Many consider "corner balanced" as either:
a) LF + RR = RF + LR
or
b. LF/LR % = RF/RR %
Or, previously "repaired" collision damage?
Sherwood
bfunke 05-23-2012 01:56 PM
A little rudder is required to overcome engine torque and p-factor...oops - wrong air cooled ride!
On your Porsche I'd carefully check tires, bearings, bushing and allignment specifications.
hcoles 05-23-2012 01:57 PM
adding confusion:
total right vs total left can't be changed
total front vs total back can't be changed
you trade off right vs left front against right vs left rear, when braking hard you want the fronts to be close ( within 50-80 pounds?) of each other. I think that is what a guy told me when he did the corner balance. I'm not an expert, just throwing in my 2 cents. In any case, what ever he did has been great for 8 years or so.
fastfredracing 05-23-2012 02:04 PM
You stating that it changes sounds when on throttle, and off throtle tells me that it very well may be a wheel bearing. Jack the rear up, and carefully look for any play in the rear wheel, grab it , and try to move it in and out from the two sides, and then from the top bottom. I also like to put my hand on the caliper, and spin the wheel by hand. A bearing that is on its way out can often be felt as roughness transmitting through the metal parts. Sometimes hard to tell, but if one side is smooth, and the other is rough and scratchy feeling, then there you go.
I have fixed more than one 911 with this condition, and I found that there was noticeable play in the rear wheel bearing . As stated above, also look for worn, or loose bushings , spring plate bolts etc...
dkirk 05-23-2012 04:09 PM
Here's my set-up:
Chassis –
• Lowered and corner-balanced (full fuel, 175 lb dr. side, 140 lb pass. side using sand bags, fuel tank 1/2 full)
o Ride height-to top of fender-front – 62.9 cm (L), 63.7 cm (R)
o Ride height-to top of fender-rear – 63.7cm (L), 64.8 cm (R)
o Angle of attack @ door sill – 1.3 deg (nose down)
o Front caster – 6.0 deg (L), 6.0 deg (R)
o Front camber - .7 deg (L), .7 deg (R)
o Front toe-in - .125 deg (L), .125 deg (R)
o Front tire load – 593 lb (L), 586 lb (R)
o Rear camber – 1.7 deg (L), 1.7 deg (R)
o Rear toe-in - .1 deg (L), .1 deg (R)
o Rear tire load – 856 lb (L), 842 lb (R)
o Total weight at setup condition – 2878 lb
o Distribution: Front – 41%, Rear – 59%, Cross – 50.1%
• Tires – Toyo Proxes
o Front – T1R 205/55/16
o Rear – T1R 225/50/16
• 6.5 mm rear wheel spacers
"Crowned Road"...Paved roads aren't flat (or shouldn't be). They are actually formed as a large radius (crown) in cross-section, with center of the road being higher than the edges. Here in WI, considerable crown is noticed on some roads, probably to better shed water from melting snow in winter. Most cars will tend to drift to the right, hands off, due to road crowning. I'm no civil engineer, so someone with more knowledge on the subject please chime in.
Hugh R 05-23-2012 04:38 PM
"Crowned road"
Jim Williams 05-23-2012 07:17 PM
Corner Balance
Originally Posted by hcoles (Post 6764176)
adding confusion:
Below is a writeup I did for the local PCA as an instruction sheet to go along with the local club's corner balance scales. It is a little long but for anyone interested, it can be cut and pasted for future reference.
Use of the Corner Balance Scales by Jim Williams
INTRODUCTION
What is corner balancing and how does it work?
Visualize a sturdy chair with legs of four equal lengths. Compare the chair to a car chassis (with four wheels).
Into the chair put a heavy object such as say a cinder block. Rather than put it in the center of the chair, move it off center, 6" back from center and 2" off to the left of center. Compare the chair above to a car, to which we will now lump all the car components, (fuel tank, battery, engine, transmission, driver, etc.) For the 911 with its rear engine, assume the weight distribution of all these components produces the same sort of off-center weight balance as will the concrete block in the above chair.
For the chair, if we never change position of the concrete block, the weight balance (front to rear and side to side) of the chair will always stay the same. The same holds true for the car. If the physical components of the car stay in the same place, the car's front to rear and side-to-side weight balance will not change.
We can calculate the position of the chair's Center of Gravity by placing a small scale under each leg. From the 4 scales, we can calculate 5 sets of figures: the sum of the front legs, the sum of the rear legs, the sum of the right legs, the sum of the left legs, and the total of all four legs. The front to rear balance is the sum of the front legs divided by the sum of the rear legs. Similar logic applies to the side-to-side balance.
Now let's trim a small amount off the left front leg, enough that with our sturdy chair, this leg just no longer touches the floor. Now the total weight of the chair and concrete block is borne by three legs, with part of the weight shifted to the right front leg and part shifted to the left rear leg. The total weight is still the same, but each leg is not carrying its share of the load. Getting each leg of the chair, or each corner of the car, to carry its proper share of the load, is what the corner balance process is all about.
SCALE SET UP
Our scale ramps were designed to accommodate different wheelbases. The center portions of the ramp dovetail for this purpose. Measure your wheelbase to position the scales/ramps. The scales must be level side-to-side or front to rear in order not to cause a bias (diagonal "jacking") in the readings. To be the most accurate, they should all be level, but for the accuracy expected for the use of these scales, may not absolutely necessary. Slight shimming under individual scales may be necessary to achieve leveling. Slip plates should be lubed and placed on top of each scale. The car can be driven slowly up the ramp, but stopped short of the scales and pushed on to by hand. If driven onto the scales, and if significant momentum is built up and braking is applied directly on the scales, the slip plates can slide off the scales, with possible damage to scales/ramps. Best to stop the car short of the scales, and push the car onto the scales manually. Also, individual scales that are not level can cause the car to slide off the plates.
Zero scales prior to driving car on.
CALCULATION OF DESIRED READINGS USING SCALES
1. (Optional) Weigh car empty for reference purposes. Note year, make, model, fuel level in gas tank, any modifications affecting weight from stock configuration.
2. Weigh car (with driver). Since the car will only be expected to perform with a driver, and the driver's weight affects corner balance and handling, it should be obvious why the driver or his/her equivalent weight needs to be in the driver's position. (If only one person is available to perform the measurement, position the scale display so it is visible from the driver's seat.)
3. Note (record) weights at each corner. Since on a rear engine car the weight bias will be to the rear, you should expect to see more weight in the rear. A 40%/60% front/rear bias should be expected on a 911. Due to the fact that seldom (read that *never*) will the Center of Gravity (CG) be in the geometric center of the car, the weights will be different at all four corners.
4. Even after the corner balancing of the car, an off-center CG will still result in different corner weights at each on the 4 wheels. This is due to the fact that the CG will still be, after the final suspension adjustments, where it was before the adjustments.
5. Although the corner balance scale readout can calculate front to rear weight bias, a short method for calculating the ideal weight to be attained at each wheel after optimum adjustment is as follows:
Designate the weights you initially measure at Left front = A, Right front = B, Left rear = C, and Right rear = D, and record these. The weight goal you want to attain for:
Left front = (A + B)(A + C)/(total weight)
Right front = (A + B)(B + D)/(total weight)
Left rear = (A + C)(C + D)/(total weight)
Right rear = (C + D)(B + D)/(total weight)
After adjustment, if everything is perfect, you want the weight to be read on the scales at each wheel equal to Lf, Rf, Lr, and Rr.
6. The above includes the necessary measurements and calculation required to do the corner balance, but leaves out the discussion of theory, and the actual adjustment procedure. I have several Excel spread-sheets that perform the calculations of the above formulas, handy if there is a laptop near to the scales.
7. Note that for some later model stock Porsches, the 996 being one, that unless the car has had a suspension modification performed consisting of adjustable coil-over shocks, the corner weights are not adjustable, nor is the ride height.
silver911rdb 05-23-2012 07:30 PM
I had the same problem when I was teching a students car for a DE. It was a 1990 C2. When I accelerated, the car would want to steer to the side. Turns out the owner recently purchased a used set of wheels with tires mounted. The seller must have just mounted some tires he had laying around...the aspect ratio was different from left to right on the rears. A new set of tires corrected the problem. The difference in dia made the car steer to the side.
diverdan 05-23-2012 10:05 PM
My first thought was air pressure in the rear tires, but a broken belt could also cause the problem.
dkirk 05-26-2012 04:53 PM
Jim W.,
Thanks very much for the detailed write-up on corner balance - copied and put into my Porsche files!
After getting the car up on the rack, torsion bar rubber bushings were inspected and appeared as new. No debonding of rubber was evident on either side. Some prying with a bar to deflect radially showed equal results side-to-side. The two control arm bushings were inspected next, with gentle prying in both the radial and lateral directions. Both appeared firm and still compliant.
Wheel bearings were next on the list. Cocking the tires and axial load inputs showed no slop in either bearing. With a stethescope against each bearing housing, wheels were rotated individually and no audible bearing distress was noted. Both rear wheels rotated freely showing that brake drag was nill.
I think I found the problem! The left-side stabilizer bar flange had a hairline crack all the way through. This was easily welded and after some grinding and painting, was almost an invisible repair. I really find it difficult to believe this was causing the problem I was experiencing, but it is now repaired and the bar is supported properly.
During the drive home, it was too windy to evaluate if the pull-to-the-right tendancy was eliminated so this will have to wait for calmer conditions. Nevertheless, a component failure was repaired and this makes me feel better.
Thanks to all who contributed suggestions - greatly appreciated!
911pcars 05-26-2012 05:46 PM
Originally Posted by dkirk (Post 6769842)
Jim W.,
Jimmy Clark had a related issue. Unfortunately, at race speed. Glad you discovered it.
Sherwood
