-   -   Couple Questions on 911 terminology and what certain modifications mean (http://forums.pelicanparts.com/porsche-911-technical-forum/679815-couple-questions-911-terminology-what-certain-modifications-mean.html)
Tidybuoy 05-24-2012 04:41 PM
My car came with a spec sheet that the mechanic/owner did to the car. This was done by the prior, prior owner so I am unable to ask a few questions. I'm hoping someone on this board can explain what these modifications mean and their benefits. The guy I bought the car from, put about 10k miles on the car over the last 10 years.
1) Oil Bypass Modification - I have no idea what this means
2) 930 Mainshaft and 1st Gear - why is this good for a normal 915 on a N/A 2.7 engine.
3) Updated 1-2 Slider, guide, and syncro hubs.
The pic below shows all the modifications but the 3 mentioned are the ones that I don't understand.
http://forums.pelicanparts.com/uploa...1337902756.jpg
Bob Kontak 05-24-2012 05:05 PM
Boat tail allows the air from a moving piston to get the heck out of the way easier.
911 Boat Tailing.wmv - YouTube
There is an oil bypass mod on youtube that you can search on. I am not sure they tell you the reason for it. Seems the prior prior guy had longevity and strength on his mind. Not a bad thing at all.
moneymanager 05-24-2012 05:49 PM
Oil bypass mod improves performance of oil pump, helps engine life.
