Cab Window problem
Ok guys I hate to admit it but I did something stupid that resulted in a 1/2" slit in the plastic window of my cab. The top and window are in great shape otherwise so to replace either or both at this point would be a costly shame. Does anyone know of a repair product or method that will work without having that "ducktape" look? Thanks to all!
If you can seam it together pretty well, I don't see why some very carefully placed super glue wouldn't work?
But be warned, everything melts that stuff. I mean, just about every chemical will melt it and make it cloudy. Otherwise, maybe some clear silicon glue or the kind of stuff that is used for mounting the rear view mirror might be in order if you can get it lined up right. Put it along the seam, get out your tape, and glue it together. |
| All times are GMT -8. The time now is 05:42 AM. |
