1987 Door Speaker Question
I need to replace a door speaker in my 1987 3.2. The existing speaker is an Infinity Kappa model that I believe is original. My problem is that the speaker baffle is a 4.5 inch cut-out that tapers down, and the only decent replacement speakers I have found require a 5 5/8- 5 11/16 cut-out without a taper for at least 1/2 inch. Also, is there something that sits immediately above the baffle a I note there is a flat indention at the top about 1 inch in? Any suggestions that would save me from removing the door panel, installing a larger baffle, etc. Would be interested in buying a used Infinity speaker that fits (the current models do not) if someone has one for sale. Thanks. JD
Old 05-28-2012, 02:46 PM
geoz's Avatar
i'm not sure the infinity is original. i took mine out a while ago because they were shot but can't remember what it was.
cheers
hg
1988 911 Cabrio
Old 05-28-2012, 03:58 PM
Hodgey's Avatar
Originals were bluespot......changed mine last year for Alpines...need to do the parcel chelf though next.....hmmmmm what to do....
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 05-28-2012, 04:02 PM
