-   -   Rolling car without axles? (http://forums.pelicanparts.com/porsche-911-technical-forum/680595-rolling-car-without-axles.html)
H Golf Sport 05-29-2012 09:41 AM
Does anyone know if it is okay to roll the car around with the axles removed (engine and trans also), or will it destroy the rear wheel bearings? How about towing the car a couple of blocks?
Thanks.
Jesse16 05-29-2012 10:05 AM
My opinion is you can do it no problem. The Drive shaft provides no support at all "in/out" for the bearing. It is a very stout bearing.
john walker's workshop 05-29-2012 10:23 AM
you need to slip in the outer stubs and tighten the nut or the double inner races will spread and possibly damage the bearing
Jesse16 05-29-2012 10:26 AM
Double inner races, had no idea. Never heard of such a thing, wonder why thats done ? Good to learn something.
MBruns 05-29-2012 10:36 AM
bearings
As JW said, even moving around the shop can spread them.
Mike Bruns
KTL 05-29-2012 02:41 PM
The driveshaft must be in for the 85.5-up cars because the outboard stub is part of the axle assembly- it's welded to the CV joint. The earlier cars that have the bolted CVs on both ends can be rolled around without the driveshafts. This is because the stub stays in place when the axle shaft is removed.
H Golf Sport 05-30-2012 08:28 AM
Okay. Thanks for the info.
