Intro - 1st Porsche - '82 911SC
Hi folks,
I figure it's time to introduce myself. A few weeks ago I finally pulled the trigger and bought my first 911 (first Porsche for that matter). It's a gorgeous, mostly stock, 1982 SC. I've had 80s/90s era BMWs in the past and it's interesting to see the similarities and differences. Owning a 911 has been on my list literally for decades (common story I know...) and so far I'm loving the car. The car is Bamboo Beige and has just shy of 90K on it. Notables:
I've got mild upgrade plans but ideally will keep the car period correct. A little faster, a little louder, a little flatter through the twisties... I've been lurking awhile and know how this board loves pics, here they are: ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking. -Roger |
Nice looking 911!!
Welcome to the Pelican family.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
more PM's than Posts
Welcome! I really like the color, nice choice. If you decide to ditch the big brake kit, let me know. I might be interested.
-Brian |
Honey Badger
Nice car! I agree with getting rid of the twists. I've never liked those on the older 911s. I wonder what motivated the previous owner to install big brakes on an otherwise stock SC?
Detached Member
Not to insult on a newbie, but I agree on the twists. Nice car.
Hugh |
Welcome Roger. Good looking car...
Join in on the 2nd Saturday of the month at the XXX in Issaquah http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/267147-xxx-saturday-breakfasts-2nd-saturday-monthly.html Thor
1978 SC coupe #1834 |
Nice purchase. I would definitely encourage you to put the original wheels and brakes back on. Not only will it look better but it will be a little faster, as well. It's hard to tell from the photos but that may be an original sport steering wheel on the car.
JR |
Welcome and nice car. Could you elaborate on the headlight 80/100 upgrade..mostly any difficulties? Big improvement? I have the parts waiting to go on my 87, so curious. Again welcome.
Nice car, will look great with the Fuchs back on and stock brakes are more than adequate!
Gary R. |
No worries, I'm no fan of the twists on these cars. It's just too much wheel. Plus these are replicas and seem to weigh a ton. Thanks all for the compliments. The car is well preserved, a nice time capsule into '82. Question for the experts regarding the brakes. The big brake kit was supposed to be a Brembo Gran Turismo, I have the original receipt and packaging. However, the fronts appear to be Boxster calipers from what I can tell and definitely don't match the rears. Fronts are branded Porsche w/a Brembo casting, the rears are a different caliper altogether labeled Brembo. Here's the question, the OEM 16" Fuchs will clear the front calipers, it's only the rear that interferes. I'm considering leaving the front as is and rebuilding only the rear OEM calipers. Any concerns there? Will my brake balance be skewed?
Thanks, -Roger '87 924S |
1983 911SC Chiffon Weiss
Very nice SC. I like the looks of the rear bumper.
Regards, mlfox |
Undocumented User
Congrats, beautiful color.
If you plan to do DE or Autocross, I say keep the upgraded brakes and buy a set of 17" Rota Fox wheels. You'll get the look you're looking for but 16" performance rubber is getting harder and harder to find. Otherwise, go back to stock since you have all of the necessary hardware. |
Yep. Not only that, I like the smaller brakes on a 911. I spent 25 years with a couple 930s in my garage, in addition to various 911s, and I can tell you that you have to be much more careful driving a car with big brakes. It's way too easy to lock a wheel on initial brake application with the bigger brakes. JR |
Nice car, never seen that colour before.
Instead of Fuchs, you might consider a set of 17" replicas. Wider is better!
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
Most 17 inch wheels, factory and aftermarket, are just too heavy. It's a night and day difference in weight between a set of 16's and a set of 17's. I can feel it from the driver's seat.
I run 15's now..., as they are that much lighter (with tires). JR Last edited by javadog; 04-23-2012 at 04:24 PM.. |
Beautiful car, but u have to go back to stock rims
"It looks like a Pleco.." |
As far as the headlight upgrade goes it was fairly straightforward, toughest part was figuring out how to remove the trim rings on my H4s. I bought the relay kit from our host PP, and also the 80/100 bulbs. The instructions that came with the relay kit were spot on. My car had the H4s already and it took me a few minutes of head scratching once I had the trim ring screw removed to figure out how to get the headlight out. Once there it was pretty standard issue. It is a noticeable improvement over the 55/100 bulbs that were in there. It's not "night and day", but definitely noticeable. I think it's worth doing. The relay kit should also prolong the life of your expensive turn signal switch, which is my next replacement project.
Great color!
Alii&Maui
FYI Your speedometer/odometer was changed, it should have the 85mph one, and the temp gauge too.
Welcome to Pelican Parts Forums
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
