Can you tell a difference???
Between the older server, and the new one? The new one should be just about as fast as the old one, except during peak times, when the older one was slowing down considerably.
Anyone experienced any slowdowns? -Wayne |
The new one seems pretty slow to me--certainly not a bit faster than the old one. And that's exacerbated by the fact that first it loads-loads-loads the complete list of two dozen bulletin boards, then requires me to choose "911 Board," then loads-loads-loads that one, whereas the old one took me straight to the 911 board. (Is that a problem I'm creating for myself? I dunno.) Mind you, I have a dial-up, steam-powered Internet portal in Upstate New York via, as Gene Hackman said in The French connection, do-ya-pick-yer-feet-in Poughkeepsie.
Stephan |
Did you update your link to the page? I got that same behavior when I kept using my old bookmark, but it's back to normal (direct to group) since I deleted the previous one and re-created it.
Emanuel |
No, no difference at all.
We still get the same threads. You know, Escort v. Valentine One, HP increase for my SC, which tires will fit my car?http://www.pelicanparts.com/support/smileys/shake.gif Still Wayne, thanks very much for all you do! Jess |
The old one (or the set-up you had before the company you were using went out of business) was a lot faster.
I was accessing your site at 6:00 a.m. PST and it was slow compared to the old one. Sorry for my honest feedback. |
The server is on a dedicated pair of T1 lines that are at about 5% utilization, so I doubt it has anything to do with the connection. I have tested this connection extensively, and found that it consistently pulls down 3.0mbs which is the max (374 kb/sec).
This is a new machine that should be about 20-70% faster at rendering the pages. It's also not shared with the webserver (was running on the same machine). So, there's no real reason why it would be slower, unless we were having machine problems (which we were a bit previously). cab83_750, do you have a cable, DSL or dialup connection? People with dialup connections can't give an accurate assessment of whether the site is fast or slow (sorry), because it is so dependent on the download speeds. In other words, the machine may render the pages in about 1/4 of a second, but it would take you 30 seconds to download. It's impossible to tell if the pages are taking 1-3 seconds instead of a 1/4 second when you're download is that slow... Searches are much, much quicker... -Wayne |
No complaints here. Seems quite fast at all times. -- Curt
It certainly isn't slower. I can't say I've noticed a real speed increase, but I never had problems in the past.
server
Wayne,
Considering where I live everything is the same. Up here in the country there's no DSL or anything like it yet, so land lines are the only game in town. I did have to change the address for my bookmark and get a new password... not big deal, thanks for the effort and a place to hang out and learn. Chas. 69 / 912 Coupe |
Wayne,
At home, I have a DSL. I work for FoxSports Net, and you could guess that we have the fastest connection anybody could have. Lastly, as I am typing this reply, the hour-glass continues to be displayed. I would guess that CPU is active even though I am just replying. In any event, you're a lot faster than RENNLIST. On the honest side, there were times when I could not access anything. I was forced to check rennlist after having been a PelicanHead for a year. |
| All times are GMT -8. The time now is 03:28 PM. |
