Choosing Tire Pressure for 79 SC
I've owned my car for just over a month, and I need to make sure my tire pressure is correct.
On the front I have "255/40ZR17 94Y". It is rated at 50 PSI max. On the back I have "255/40ZR17 94W M+S". It is rated at 51 PSI max. They are Falken FK. All tires are currently 27-33 PSI. My owner's manual says 29 front, 34 rear. Based my searches and some guesswork, I've concluded that my tires are on 17" rims. The front is about 9" wide and the back is about 10". Should I go with the manual's pressure? I suspect its cites pressure for the original tires, and these should be loaded differently. ![]() ![]()
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Northern Motorhead
The rims look like Cup 1 replicas most likely or Oem's if you have large spacers and are 7 1/2 inch wide for the fronts and 9 inch wide for the rear.
Stick with the 29 and 34 psi rating and you will be fine.That's what i run my 17 inch tires at for street driving. Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
