help, gear shift went all noodley
I seem to have lost 2nd and 4th gear in my 73 911. The gearbox, I believe, is a 915. The shift lever doesn't want to pull back far enough to engage 2nd or 4th, and suddenly the lever itself feels very loose. Could I have broken something? It happened very quickly.
Help/thoughts appreciated, gary |
Flat Six
Shift coupler bushings, I'd bet. Check in access panel between/behind front seats. Bet they're toast. R&R. As long as you're doing that, replace shifter cup bushing and shift rod bushing in tunnel between seats.
Plenty of threads detail the diagnostic, replacement, reassembly, and adjustment processes. Good luck Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Location: A scenic and exhilarating drive along the Delaware River just one hour from Philadelphia, PA
. Unless it's a simple issue of adjusting your shift coupler due to the coupler's clamp and/or set screw coming loose, yours will probably look similar. FYI, this weekend I plan on posting a step by step tutorial of my bushing replacement with lots of pictures.
+3......In my '73, they went TU overnight.....Thought I was into big coin.......Did the coupler and cup bushings for about $25 in parts.......Was in Tall Cotton again.........
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Hey Targa guy,
Pulled the cover off the trans coupler this morning and you were spot on. There were no bushings left, just ground up plastic. Ordered replacements from our host. How do I remove the center pin? Just press it out from either side? Anything I should be especially careful of? Thanks, gary |
yes, you press the pin out.
DO NOT put pressure on the outer aluminum housing. Instead, put the steel shank into the vice while leaving the housing to float in the air. Tap the pin out. Rich |
I have had the pin come out before during a spirited drive.... Good thing I was close to my shop.
1979 911 SC... 83 911 SC .... 82 911 sc.... Fiat 124 Spider Full Race |
Rich, great advice. Pin came out with no problem. I suspect that was the easy part, right? Getting the pin back into place with the bushings inserted doesn't leave much room to get the shank into a vise without getting into the splines and not being able to put pressue on the aluminum will be tricky. Again, what do you advise?
Thanks, gary |
it can just bite enough in the vice.
You dont need much pressure with new bushings and a clean pin. I used the vice and a socket that was smaller than the aluminum....but larger than the pin. One side of the vice presses the pin, the other side is pressing the plastic bushing. that was just at the end... to start, you can almost do it in your hand with a small hammer to tap is in. The housing will break if you push against it...so do everything in your power to resist that tempting way to solve your problem... Rich |
Flat Six
HTH Dale
'noodley'......... I like that.
same symptom--different cause?
Searching threads on this issue. My 1973 E shifter also went 'noodley'. No apparent issues in the bushings found in the tunnel behind the seats. When I move the gear shift lever it has a lot of play, particularly side-to-side, but the bushing does not move. I can shift, it is just so sloppy a missed gear or hitting the wrong gear is bound to happen. Up front, where the lever goes into the can, I don't see anything obvious. Ideas? Also, how does one remove the shift lever housing without cutting the carpet? Seems the bolts are deep under the tight carpet covering the tunnel up front.
Thanks, Jeff |
Shift into neutral, then pull the shift lever housing assy. straight up. Inspect the ball bush (45) and the shift shaft bushing (44), both are nylon and probably worn or perhaps in pieces. In some cases, the two-piece lever might be loose or actually separated. '73-'86 on left, '72 and older on right ![]() Let us know what you discover. Sherwood |
To get my pin out I removed the old bushings FIRST, and then was able to simply tap out the pin using a couple of properly sized sockets and a hammer. No big deal at all.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
If its not the shift coupler bushings, the pin holding the shifter to the ball may have broke. Your symptoms suggest that. Check the drawing and you can see where the pin goes #27 or 7. Good luck. My 69 does not have a pin. I had to get it rewelded when it broke after 42 years.
69 911 2.3Ez 85 928S |
Pin 7 breaking is possible but highly improbable (915 shifter) However, to support your fix, in all cases, shifter separation is inevitable as the two-piece lever is assembled with epoxy with a duty life of approx. 25 + X years (X is variable). Sherwood |
Interesting - my pin was frozen into the splined part and I ended up mushrooming the pin so I just bought a new coupler. Be sure to get the 914 bushes as they are round not oval and will give you less slop. Best technique I've seen is to cut a block of Aluminum and drill the end fit the splined part. Put the block in the vise and then tap the pin out.
Thanks everyone. Looking at this in earnest this weekend. I called the local P-car (independent) mechanic for his opinion. He expressed that the needed parts, whatever they might be, are difficult to get. If it is a pin I can maybe make one. Onward through the fog.
(BTW, my carpet is under stitched vinyl at the edges. looks original and it is in very nice condition for a 1973. It won't be nice much longer...) |
Ended up ordering a new short shift kit. The old stuff was worn out, including the metal that held one of the bushings. Not too happy with the shift feel now, however. At times it feels very stiff, like an over pressed bushing. I assume that will loosen with a bit of use (20 miles thus far).
A bigger concern is that the confidence in the shifting is gone. It was always easy to shift and have the right gear--now each shift has to be conscious. Any ideas? Jeff |
86FlatSix
I just changed the shifter coupler last Saturday thru the help of some Pelicanites. I also experienced struggle in shifting and downshifting. I could not be happier with my new shifter couplers. This made it easier for me.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
