-   -   Need Pictures of Trunk Areas Nicely Finished and Uncarpeted (http://forums.pelicanparts.com/porsche-911-technical-forum/681481-need-pictures-trunk-areas-nicely-finished-uncarpeted.html)
joefrantz 06-04-2012 09:32 PM
There is really some nice stuff turning up here.
Craig T: Yes there is an Odyssey 680 in the box.
http://forums.pelicanparts.com/uploa...1338872878.jpg
Randy: The lift-off conversion is pretty low tech.
The screw holes for the lid hinges are recessed slightly in the body.
I found some rubber plugs with a cone shaped end that fits into the screw hole recesses.
I attached the plugs to the lid hinges with sheet metal screws and a bit of trim adhesive.
When in place, the plugs ride in the screw hole recesses, and the original latch holds it all down. The fit is tight enough that there is no movement or rattling, but loose enough that everything just lifts off when you open the latch.
http://forums.pelicanparts.com/uploa...1338874048.jpg
http://forums.pelicanparts.com/uploa...1338873949.jpg
http://forums.pelicanparts.com/uploa...1338874274.jpg
RWebb 06-04-2012 09:34 PM
thx - I thought maybe you'd welded a lip onto it
proffighter 06-04-2012 11:15 PM
Here is mine, not finished but nice;)
http://forums.pelicanparts.com/uploa...1338880521.jpg
NoLift911 06-05-2012 04:27 AM
What is the story with the dual M/C resevoirs?
proffighter 06-05-2012 05:16 AM
Had the M/C at the pedals without booster a few years ago, so there was need for relocating the reservoirs and I felt a lonely stock one is ugly. Later I went back to the booster and kept the reservoirs as they are nicer and better for bleeded by hand (or automotive bleeder)
NoLift911 06-05-2012 05:23 AM
Exactly - I think they are better for bleeding as well - where did you get them and how is your hose routing set up?
proffighter 06-05-2012 05:42 AM
You mean setup before booster? Like this:
http://forums.pelicanparts.com/uploa...1338903637.jpg
Reservoirs are from here (brand AP Racing), but there are others too. Maybe not that cheap to send to the US:
ISA-Racing Online Shop - Flüssigkeitsbehälter und Zubehör
dsfnctn 06-05-2012 07:18 AM
here is minehttp://forums.pelicanparts.com/uploa...1338909496.jpg
AirKuhl 06-05-2012 09:43 AM
Nothing fancy but it's pretty clean. Only unique feature is that the tank is painted black instead of gray and the underside of the hood is finished, like the exterior.
http://forums.pelicanparts.com/uploa...1321708746.jpg
Craig T 06-05-2012 09:53 AM
That's all I'm looking for...Clean and simple.
skinnerd 06-05-2012 12:30 PM
Here's mine.
Odyssey in the smuggler's box.
http://forums.pelicanparts.com/uploa...1338928203.jpg
Fastdog911 08-18-2012 02:50 PM
kudos to the nice looking trunks on this site... this is how mine looked when I bought it.. my question would be is this how it came from the factory? I have a 70T. http://forums.pelicanparts.com/uploa...1345329984.jpg
http://forums.pelicanparts.com/uploa...1345330025.jpg
KFC911 08-18-2012 03:33 PM
Nuthin' fancy...just stuff I don't/can't use removed (smuggler's box is empty too)... http://forums.pelicanparts.com/uploa...1345332830.jpg
Rob T. 10-24-2012 11:27 AM
My new one.
Not quite finished but close to ithttp://forums.pelicanparts.com/uploa...1351106647.jpg
http://forums.pelicanparts.com/uploa...1351106746.jpg
http://forums.pelicanparts.com/uploa...1351106850.jpg
wildcat077 10-24-2012 04:35 PM
Rob,
Where did you hide your fuse panel ?
That is one clean looking trunk area you have there and surely some heavy duty bracing :)
Cheers !
Phil
quozl 10-24-2012 06:37 PM
http://www.users.on.net/~quozl/Image...MG_4258vsm.JPG
Rob T. 10-25-2012 10:19 AM
Hey Phil
My fuse panel is under the dashboard.
It´s not easy to change a fuse but it looks very clean.
I like the naked look...
http://forums.pelicanparts.com/uploa...1351189148.jpg
Nickshu 10-25-2012 04:16 PM
Wow those are some nice looking "frunks". I though mine was pretty clean, but damn these put mine to shame.
One question...how did you remove all the black goop around the strut top mounts? I'd like to get mine cleaned up here.
Flying Toaster 10-26-2012 07:09 AM
Sorry for the bad iPhone pic.. Braille battery in smuggler's box.
http://forums.pelicanparts.com/uploa...1351264047.jpg
911jettat 10-26-2012 08:15 AM
Wow Rob T. I'd love a 964 version of your frunk.
Naked 964 frunk below (with just a floormat coving the spare tire).
https://lh3.googleusercontent.com/-J.../s1024/025.JPG
