Porsche Crest What kind of maintance is required after 90 min of track time
Do I need to adjust the valves ? I cheaked them and adjusted about 200 miles before track. Change oil?? New mobil one before track brakes still work great .. Can I go for drive today..
You can stick a Beetle motor in a 911.But you can not! Put a 911 motor in a Beetle....
Wayne Savage 72S MFI
Old 08-04-2001, 10:25 AM
Administrator
Jack Olsen's Avatar
Post
If your brakes aren't spongy, you're fine.
Old 08-04-2001, 12:22 PM
andyu911's Avatar
Wink
I usually change oil and filter, check brake-pads, rotors and fluid and adjust tire pressure for street use. I do the valve adjustment once a season, unless something suspicious.
Andy
'87 Carrera
Old 08-04-2001, 12:23 PM
Early_S_Man's Avatar
Wayne,
How long since you changed gear oil?
What do your valves sound like today?
More than likely, no problem with a drive ... today, or any other day!
Warren Hall
1973 911S Targa
Old 08-04-2001, 12:34 PM
Post
Hi. I pulled the plugs to get an engine condition. And damn the spark plug boots sliped off 2 and 5 and the spark plugs had a little oil on them.I cleaned them up put the air boots on correctly and fired it up.. It sounds great no smoke seems ok. I readjusted tire pressure Gear lube has about 2k on it brakes,Well they worked good when I pulled into the garage..The Track day was cool at PIR in Portland except for those peesky 2001 Corvettes and a Viper in my intermidate class got spanked real good Those tires on those cars are two feet wide!! allmost.. All I could do was go into the corners deeper and brake harder. And have balls on the strights full out to 130 or so, that would lose about 10% but the other 90% made me drop back to novice for the last session.. Oh well I only have 2.5 hours of track time I will get there..
Old 08-04-2001, 12:49 PM
