SLR SLR is offline
SLR
Rust in side sill heater duct.
Hi all
just noticed a small rust bubble coming up under the paint on the drivers side
lower sill. at the rear end where there is a welded seem. so out with the dremall
and the hole got bigger and bigger. about 2" x 3/4" not that big. so treated with rust killer
( i will do it properly over next winter ). I notist some dry dirt in there. I was thinking of sticking the power washer up through the flapper valve and see if I can remove any more
dirt ? I'll raise the front of the car to let the gunk out... can this be done ?
Thanks for any help.
Old 06-04-2012, 12:14 PM
300hp 1800lbs is the goal
pksystems's Avatar
I wouldn't spray water into any hollow cavities on the car. Long wire brush and a shot of air from a compressor to clean it out.
What year car.
The early cars don't get much in terms of rust protection on the inside of the hollow cavities. They generally rust from the inside out.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 06-04-2012, 01:08 PM
SLR SLR is offline
SLR
Sorry it is on a 1985 3.2, A brush kinda makes better sense. then use some kinda
of rust stopper, like fish oil, or there is a rust protection wax that is sprayed into cavorts
but I'm thinking the heat may melt it out?
Thanks Steve.
Old 06-04-2012, 02:24 PM
DG624's Avatar
Delay means more repair...ask me how I know.
Old 06-04-2012, 02:48 PM
SLR SLR is offline
SLR
DG624 thanks and I know you are right....
Old 06-04-2012, 02:53 PM
