tire inflator/compressor
went looking for mine in the trunk today to no avail - where exactly do people typically store these? maybe I'm over-looking a compartment/etc..problably will have to get one..
Dave, '86 Cab |
Compressor.
Ours is part of the tool kit assy which is kept in the boot. Good luck, Gerry http://forums.pelicanparts.com/uploa...1338849493.jpg |
looks like a tool kit
are you saying there is an electric air compressor in there? :confused:
1. A Guards Red small paint sample. 2. Tool kit. 3. Tire pressure gauge. 4. Compressor. 5. Plastic gloves. Also, there are a few for sale on the Used Parts forum. http://forums.pelicanparts.com/uploa...1338932605.jpg |
smuglers box
thanks guys. Oh.., my tip'o the day: before you buy a headlight to replace the failed high beam, replace the fuse EVEN IF IT LOOKS OK. New sealed beam had same problem and I was ready to trace wires and look for shorts etc until I decided to go back to my original checkpoint and and see if I had power on both sides of the fuse when I put the highbeams on - dang that normal looking fuse was bad!....on the plus side got look at headlight assemblies and treated some rust before it gets out of hand...
probably, can't say for sure - threw it so far we'll never know...!
| All times are GMT -8. The time now is 05:46 PM. |
