After the next project
Draining fuel tank (91 911) and fuel pump location help
I am use to my old 930 where fuel pump was visible. On this 91 911 C2 there is all of the plastic underbody covering. Is the fuel pump still visible if I remove that plastic covering on the under carriage? Also, if I'm draining the fuel is that an adequate place to remove a line from the fuel pump rather than trying to extract or siphon the fuel from the filler hose on top?
Thanks for the help in advance. Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Bryan,
Fuel pump is located on the bottom roughly under the passengers feet. It's covered by a triangular shaped metal plate. You can drain the tank by the feed hose
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Dan, thanks for the help and quick response.
