Rear Seat Pads?
Mine need to be replaced and they are made out of that Horse Hair fiber fill stuff. Does anyone make a Foam Pad replacement? Or anywhere I can send my pads and have them Re-made?
I used trhe search and went to the classified section and saw a nice set of Tan but no Black. At lease I do not need this to operate the car!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 1982 BMW 320i
Old 06-07-2012, 08:36 AM
try Tony at Autobahn Interiors Specializing in Excellent Porsche Interiors
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-07-2012, 08:45 AM
Garage Queen
PorscheGAL's Avatar
Do they need to be replaced or do they just need to be recovered?
If you need recovering that is a pretty easy job to do yourself with a seat kit from worlduph.com and a can of 3m adhesive spray. I can walk you through this if you need tips.
I have never seen replacement pads. If they need to be completely replaced, I think your best shot is to take the old pad into an upholstery shop and have them cut a piece of foam to the correct size. The one issue I see with that is that foam is more box shaped and may not lay the same way in the space provided.
Stephanie
My minions:'86 911 Targa 3.4, '87 930, '05 Lotus Elise,
'19 Audi RS3, '13 Focus ST, '16 Focus RS
Old 06-07-2012, 09:00 AM
Originally Posted by RSTarga View Post
I sent him a message! Thanks
Old 06-07-2012, 09:30 AM
That is the issue! The Junk they were made out of is mostly gone and just the cover remains. Sort of hard to recover something that is no longer there which is why I want a foam Pad so I will always have the Basic Part of the seat and some cushion no matter what!
Old 06-07-2012, 09:38 AM
airbil
airbil's Avatar
Wickes aircraft supply seat foam cushions "may" work.
Wicks Aircraft Supply
I'd go "blue", medium firmness. YMMV
75 Carrera, 06 CttS, 95 Audi urS6 Avant, 97 M3/4/5, 07 Audi S6
Old 06-07-2012, 09:48 AM
I think "YOU" have struck the nail on the head!! This I am going to buy and clean out the Junk in my seat cushions and clean them up and clue to the foam and have better than stock AND not spent a ton of money!!
Thank you!!
Old 06-07-2012, 09:58 AM
Resurrecting an old thread here....
I'm redoing most of the interior on my '73, including rear seat upholstery. However, the seat bottoms are toast (a PO appears to have used expanding foam on the bottoms, probably because they were disintegrating). Did you end up using the Wicks stuff? If so, how did it work out?
--Richard
1965 356 SC Coupe
Old 04-10-2015, 12:16 PM
Still have it and still Happy. The Blue Foam is about the Right Thickness AND has not Changed Density. I have moved to Fla and have a Piece outside near the Pool and the weather has not changed it either.
I am STILL Thanking AirBill!!
Old 04-10-2015, 12:38 PM
Excellent! Thanks for the response.
--Richard
1965 356 SC Coupe
Old 04-10-2015, 12:53 PM
Thanks for the link, it looks like it's expired. Is this the same product from Wicks?
Item # 19018, Seat Cushion Foam On Wicks Aircraft Supply
Old 08-14-2019, 12:44 PM
