-   -   When Removing Engine and Transmission Together as a Unit... (http://forums.pelicanparts.com/porsche-911-technical-forum/682444-when-removing-engine-transmission-together-unit.html)
scotricker 06-08-2012 07:12 AM
Do I need to drain the Transmission oil first? I am not planning on separating the two this time. Will it be a big mess? Or will it be OK?
timmy2 06-08-2012 07:14 AM
I didn't drain mine, no spills.
Just don't turn it upside down!
tobluforu 06-08-2012 07:15 AM
No you don't but if your plan is to drain it when you drop it, then I would do it before, much easier.
CCM911 06-08-2012 07:15 AM
No need to drain the trans. Nothing will leak.
But be aware, even though you will have drained the engine oil, it will still be messy. You may want to have a good selection of plugs to prevent your oil lines from dripping.
Ask me how I know. :)
scotricker 06-08-2012 08:11 AM
OK, thanks for the tips!
Quicksilver 06-08-2012 12:57 PM
Even if you separate it the trans won't leak.
