How hot does your car run?
I recently had my wrench adjust my mixture and set my idle on my 87 3.2 because of a rich running condition (intermittent black smoke on acceleration) Afterwards I noticed a difference in engine oil temperature.
Normally my car at operating temp read about 1mm below 90 degree's celsius (1st white hash mark) on the oil temp gauge. Now, post tuneup, it runs about 1mm above 90 degrees on the guage. From researching the archives it seems leaner engines run warmer than rich engines. So is this roughly a good operating temp for my Carrera or am I running too hot? How hot are your cars running? Thanks, Michael 87 Targa |
90C is about 194 F. I remember from my flying days that leaning out a air/fuel mixture results in higher EGT ,exhaust gas temp. and and cylinder head temp. So running a little hotter seems reasonable.
bump
| All times are GMT -8. The time now is 04:30 AM. |
