sdeason1's Avatar
Need Help: SWB Restoration panel replacement
Hi Guys,
I'm restoring a very rough & rusty '67 swb 911. As I cut out rusty sections and replace with new metal, what should I paint/coat the inside of sections of the chassis that will be closed off once everything is welded up? For example the void between the smuggler's box, steering rack "hump" and inner fender well. No paint will be able touch these after it's closed off. Thanks for any suggestions.
Bondo sucks.
Old 05-29-2012, 07:08 AM
Bird. It's the word...
Fishcop's Avatar
Yes. Take any opportunity to protect both sides of the metal. If you can't get hi-zinc content paint in there, at least get a wax/oil product coating over the surfaces.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-29-2012, 05:47 PM
air+fuel+spark
combatic's Avatar
+1
There are a variety of ways to tackle...some people epoxy prime everything...grind back to weld the spray waxiol or similar product through access holes.
Check out Fishcops or my build for different approaches
bryan
1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle
R Gruppe #653
Old 05-29-2012, 06:01 PM
sdeason1's Avatar
Thanks guys!
The voice of experience is always welcome.
Bondo sucks.
Old 06-09-2012, 03:17 PM
300hp 1800lbs is the goal
pksystems's Avatar
Eastwood internal frame coating
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 06-09-2012, 03:37 PM
