-   -   Adding fuel return line MFI (http://forums.pelicanparts.com/porsche-911-technical-forum/682733-adding-fuel-return-line-mfi.html)
porschemn 06-09-2012 05:25 PM
Could use some help on where to drill hole for adding line. I found a plug in the rear, but not in the front by fuel pump. I've read that the fuel lines run on the left side of the tunnel. I enclosed a pic of the front line. The pic is a little fuzzy, but can see brake and main fuel line. Any pics of your MFI setup would be great. I'm thinking off drilling a little to the right of other line?
Matt http://forums.pelicanparts.com/uploa...1339287746.jpg
porschemn 06-10-2012 07:03 PM
Anyone?
James Brown 06-10-2012 08:57 PM
did you look at the parts break down manual? that will give you a idea where the lines should be
BoxsterGT 06-11-2012 04:28 AM
Here's a shot from JeremyD of his 74 which should be close to what you need, as 74 still had MFI in Europe.........
http://forums.pelicanparts.com/uploa...1339410500.jpg
The White (original color but now brown) Nylon tubes on these era models are to be removed & discarded, as they crack & fall apart from age.
Yours should be steel, but better to do both in Stainless Steel. I can provide Metric Flare fittings for both the 8mm & 10mm SS tube to use normal metric fuel hose fittings, and can provide crimped Hi-Pressure hoses for your MFI if needed.
http://forums.pelicanparts.com/uploa...1339414019.jpg
Len at Autosportengineering dot com
Fishcop 06-11-2012 06:18 PM
You don't need to drill. The hole is already there, just remove the bung...
