Here are the pics of the starter alignment and the collection of rings I`m starting to accumulate. I betcha I can R&R that engine blindfolded now!! Did I mention our driving season up here is fairly short.
http://forums.pelicanparts.com/uploa...1340073510.jpg http://forums.pelicanparts.com/uploa...1340073546.jpg http://forums.pelicanparts.com/uploa...1340073583.jpg |
Starter must be running while the engine is running somehow. Maybe some fault in the ignition switch possibly?
Does the starter engage normally ???
Are you sure it goes back after starting ??? |
The starter sounded perfect when it was working. It definitely disengaged properly when I let go of the key. I found this link last night which looks exactly like mine.
http://forums.pelicanparts.com/porsche-911-technical-forum/558692-3-6-conversion-starter-problem.html Where are these rings being manufactured? |
It looks like the starter teeth are hitting the bolts that hold the ring gear (based on condition of the bolt) Is that possible?
Long shot but. Are locating dowels still in place between the engine and trans? I can,t recall what should be there originally but without them could the bell housing be slightly offset from the block?
In both cases, the teeth are chewed away at the exact same place, where the engine stops and the starter initially engages.
Wow, that is pretty amazing! If you think it might be a bad batch of ring gears, post a wtb a ring gear and get one that is used and test it.
If the starter was running/engaged on the RG, you would hear it, ask me how I know because it sounds like your engine is about to let loose? I have posted this a few times and it worked for me when it was hung up, shim it. |
I think you should call Jim Patrick He's done an awful lot of these
Patrick Motorsports - Custom Porsche racing parts and services. |
With the amount of time and money you're putting in, I would run this engine on a stand so I could see what was happening real time with the ring gear.
with the way the teeth are broken, mostly on an angle toward the starter, maybe the hi-torque starter is the culprit. if the starter teeth engage the ring gear teeth too far out toward the tips of the teeth, they would have a lot more leverage to break them off. same if the two gears were not fully engaged across the full width of the teeth. are there any witness marks on the other teeth that may support that idea? i think i would go back to a stock starter. they work just fine.
| All times are GMT -8. The time now is 09:20 PM. |
