Does anyone know the size of the chain tensioner alu bushing?
Hi,
I'm installing hydraulic chain tensoners, but I am missing the little spacer that usually come with the kit. Could anyone please provide the dimensions, so I can have it made new? Thanks, Johan |
Just to clarify, the spacer between the tensioner and the idler arm.
Johan |
Fixed it, for future reference the size is 10 mm thick, ID 15.2 mm, OD ~27 mm.
Regards, Johan |
Get some wide idler arms and you won't need the spacer. The problem you're trying to solve is chain tensioner failure and the complete solution involves wide idler arms.
andy |
| All times are GMT -8. The time now is 09:04 PM. |
