Northern Motorhead
wildcat077's Avatar
Sloppy steering ? heads up ...
Hey guys,
My steering was feeling sloppy since my last track outing three weeks ago and i started reading all the posts about lunched steering "u" joints and many other atrocities until i did my one week prior to "track inspection" only to discover that one of my steering rack bolts had completely loosened and the other was only finger tight.
I had installed bump steer spacers three years ago with blue 242 Loctite and they managed to come loose,and yes i installed 1/2 inch longer bolts to compensate.
This time i reinstalled them with red 271 loctite and will pay more careful attention
even though the guard plate is a PITA to remove/install.
Just a heads up to remember to check those bolts from time to time !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-11-2012, 12:44 PM
Taking it apart is easy
Jerome74911S's Avatar
Good advice.
A little bit more precise photo would be useful.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 06-11-2012, 12:54 PM
Northern Motorhead
wildcat077's Avatar
Originally Posted by Jerome74911S View Post
Good advice.
The red bump steer spacer in the picture is where the bolt for the steering rack is ... you have one on each side of the fuel pump ...
Cheers !
Phil
Cheers
Phil
Old 06-11-2012, 01:24 PM
French Import
zippy_gg's Avatar
And you appear to be missing a bolt on the sway bar mount where the blue bushing is, but you probably already knew this.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-11-2012, 02:39 PM
Cheers !
Phil
OK, I get it, but on my car there is no fuel pump there, nor is there a guard plate. I'll have a look at it.
Jerome
Old 06-11-2012, 02:57 PM
Northern Motorhead
wildcat077's Avatar
Smart guy,you missed the nut on the forward bolt that holds the cover plate ... but you probably already knew that too !
Kinda hard to take pictures with the cover installed ...
Get a life ... there's no need to make irrelevant smart ass remarks on people's posts!
Cheers !
Phil
Cheers
Phil
Old 06-11-2012, 04:38 PM
Cheers !
Phil
Well, that's pretty over the top, Phil. Then you say "Cheers"?
Jerome
Old 06-11-2012, 05:23 PM
French Import
zippy_gg's Avatar
Cheers !
Phil
Wow, excuse me for my ignorance as I haven't gotten to work on that part of my car yet...
I just noticed you were missing a bolt, that's all...
Gilles & Kathy
Old 06-11-2012, 07:28 PM
Dang, it's like the Wild West, one comment taken the wrong way and U'r in the shoot out at Hi-Noon.
Ha
73 911 T MFI Coupe, Aubergine
Old 06-11-2012, 07:36 PM
