tailwind22's Avatar
89 turbo tire fit question
New to the forum and love the volumes of info to be found. Anyone know if a set of Fkse 18s with 225/35 front and 285/30 rears from a 993 will fit a 89 930?
Old 06-22-2012, 04:26 PM
Are the wheels 8 & 10's? The early model 911 and the 930 need a low offset wheel to fit without the use of spacers the late model 964/965/993 and the 993 TT use high offsets and most will need 1" on the front and 2" or possibly 3" on the rear. The hoops needed are completely different for the 930 models. When I build sets for 930 cars I use 2.25" outer front rims and 5.75" inner rims = 8.25" front wheels no spacers on the fronts. In the rear I use 4.25 - 4.75" rear outer rims and 6.5" inner and you remove the rear factory spacer and cut the studs. Everybody wants the deep lip wheels. Jim
jdorociak@gmail.com
Old 06-22-2012, 04:36 PM
tailwind22's Avatar
Thanks, that helps a bunch, good info.
Old 06-22-2012, 10:05 PM
