-   -   One more 3.0 CIS question (http://forums.pelicanparts.com/porsche-911-technical-forum/68315-one-more-3-0-cis-question.html)
dd74 05-12-2002 11:57 PM
Hi all. Back to the engine section again:
I know the horsepower rating for a stock American 3.0L is 180. But does that rise in power if back-dated heat exchangers from a '74 are used in conjunction with, say, a Bursch dual inlet, single outlet muffler? And if so, how much might the final horsepower be? Anyone know? Secondly, what's the difference between a 180 horsepower American 3.0L and the 204 horsepower European version? Is it just the higher compression ratio (8.5:1 vs 9.8:1), or is there more to it than that? Can a 9.8:1 compression 3.0L run okay on California 91 octane super-unleaded pump gas?
Thanks for your input.
304065 05-13-2002 07:08 AM
CIS
I'll be interested to hear from the experts on this one. I do know that much of the difference between the Euro CIS and the US version was the emissions equipment- which can be deleted for off-road use.
My PCA Club Racing run group at Lime Rock included SC's. At the end of the straights, more than a couple of the cars would shoot fire out of the tailpipes for about 6". That doesn't happen unless you are running an incredibly rich mixture in an NA car. So there are definitely tricks out there to get CIS to produce big power.
dd74 05-13-2002 07:53 AM
Hey John:
Excuse me but what's an "NA car?"
911jon 05-13-2002 08:03 AM
Early Euro cars (78 to 80) also used low compression pistons for 180bhp nominal rating. 1980 (might have been '79) cars were re-rated at 188bhp though no change was made to the motor. Porsche simply found the earlier statement of output to be overly pessimistic (typical of the company at that time).
The later high-comp engine was introduced for the 1981-83 model years rated at 204 bhp. These are nominal, average figures. Bear in mind that with a fine tolerance, hand-assembled engine, power output figures vary considerably from one unit to the next. Time also takes it's toll!
I cannot comment on US spec cars, don't know exactly what emissions equipment was fitted, but that was the story over here!
And no, I wouldn't try to run a 9.8:1 car on low octane fuel. Detonation would almost certainly result. How do you cope with 91 octane fuel! Our basic fuel is 95 octane, and I use the widely available 98.5 octane we have now. Sorry, shouldn't rub it in! ;)
sammyg2 05-13-2002 08:14 AM
NA means normally aspirated, IE non turbocharged or supercharged.
Yes, you can run an SC on 91 octane US spec gasoline. That number is an average of research octane and mechanical octane and is as good as you can get in most places around here unless you buy special fuel.
Some countries use one of the octane rating systems, but not both. That gives them a higher rating with the same gasoline.
makaio 05-13-2002 10:11 AM
Jon, I thought the German government had a 3 % policy. Where all motors had to be within 3% of the claimed output. Either + or -.
I could be wrong, but I thought I read that before.
dd74 05-13-2002 10:39 AM
98.5 = $$$
Yeah, 98.5 is hard to come by. Out here in L.A., you can get it from select stations, but it's 5 bucks or more a gallon, I think. But isn't that about what you guys are paying in the UK?
dd74 05-13-2002 10:42 AM
Hey Sammyg2
So in reference to Jon's statement about 98.5, what happens when you run a standard SC motor on octane like that, particularly with 8.5:1 compression? Any ideas? Anyone have any ideas?
Thx
Wayne 962 05-13-2002 12:51 PM
8.5 is low enough to be run on regular gas. 9.8:1 may be pushing it. The weird CA blends out here do suck big time. I can't get my 325is to stop pinging (and it has a knock sensor!)
-Wayne
