BUT if you can't the inner out. you can move the outer plate almost in a circle, there full splines. BUT if your stuck between measurements, then you might have to remove the bar and re-index it to get the desired ride hight. BTW, new shocks effect the ride hight so keep that in mind.
I cannot get the the inner TB to free up. I can jiggle move the TB up and down and right and left a 1/4in or so but it will not come out. I've sprayed in PB blaster and used Vise-grips with prybars. Is there some inner bolt or clip that needs to be removed?
If you've got the other side out put a long bar in from the other side and drive it out. |
Sway away adjustable spring plates allow for a couple inches of fine tuning.....just sayin'.....
Todd |
Remove the spring plate from both sides.
Give either torsion bar a couple of good wacks with a small sledge using a wood drift through the removed torsion cover. Repeat on other side until both bars can move. |
Did you ever get the car lowered? I need to lower my rear also and looking for any info I can find.
| All times are GMT -8. The time now is 10:08 PM. |
