Mark Wilson
Guest
Posts: n/a
Parking light problems
I noticed last night that both front and back left side parking/sidemarker lights on the 79SC had quit burning. The turn signals are still working. I replaced all of the bulbs and cleaned the contacts but still no go. Any suggestions where to look next?
Thanks,
Mark
Old 05-19-2002, 03:57 PM
stormcrow's Avatar
Clean the housing that the bulb sets in. I had the same problem with mine when I replaced the bulb. If the body of the bulb does not make good contact with the housing, it won't light.
Old 05-19-2002, 05:14 PM
critter's Avatar
I just spent half a day on my car chasing the exact same problem,I learned that my car has a seperate fuse for the left side verses the right side park lights.There was a bit of corrosion under the fuse,cleaned it up and it all works good now.
Grant 75 911s targa
1991 Dodge Cummins turbo diesel 3/4 ton 4x4 ( stump puller)
Old 05-19-2002, 08:01 PM
Mark Wilson
Guest
Posts: n/a
Thanks Guys!!
Old 05-19-2002, 08:03 PM
Mark Wilson
Guest
Posts: n/a
Problem solved.
Grant, You saved me a world of grief. I just checked and there is a blown fuse. I would never have thought about separate fuses for each side.
Thanks again.
Mark
Old 05-19-2002, 08:36 PM
