vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Cracked Fan Housing?
Replaced the alternator this week, and when I had it all apart and cleaned up the housing noticed what looked like stress cracks in the housing. They appeared to get more stressed when I bolted the alt back in! I am hoping after I get the whole thing back in that I will be OK.
Anyone ever welded the fan housing? What kind of alloy is it anyway?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 03-29-2002, 05:55 AM
jabb's Avatar
I believe it is Magnesium.... It can be welded
but you need to find someone that knows how to weld Magnesium.... I would get it fixed before putting it back together. If you have no luck
finding a welder you should be able to pickup a used housing....
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 03-29-2002, 05:59 AM
Senior Member
Vance,
Found exactly the same thing in my fan housing. Welded it up at a local shop for $25. It is a mix and not for a home welder (unless they are very good) to try.
Joe
Old 03-29-2002, 06:29 AM
Send a message via AIM to 83SC in PA
I just had it done too and my welder said it is a mix of magnesium and tin. Very hard to weld, but he got it done for me.
83 911SC Coupe(Chiffon)
02 SL500(Black)
88 M5(Black)
77 Scirocco(Diamondsilver metallic)
74 TR-6(Magenta)
Old 03-29-2002, 01:14 PM
Send a message via Yahoo to FRED/LI
On reinstalling, be cautious when tightening the strap. Too tight will cause the stress associated with causing the cracks.
Fred '95 Carrera2. Previous: '69S, '79SC, '84Carrera, '90 C2, 20+ years and counting......
Old 05-13-2002, 05:54 AM
