Replacing lower valance
I am going to replace my lower valance this weekend while I am doing this job I am going to replace the front smile also.
I have working AC and the front condensor unit is right in the middle of this job, can I do this project without having to totaly remove this unit . If you have done this advice would be very helpful :rolleyes: Thanks, GB83SC |
If its factory air, the condensor isnt in the way at all. It looks tight in there, but once you remove the valance you can see much better. The smile has some screws that come in from inside the trunk. With a small (1") screwdriver, or angle type you can easily get to the ones behind the front fan motor.
| All times are GMT -8. The time now is 11:47 AM. |
