When Taking Out the Engine and Trans Together..
Do I need to remove all the clutch levers and springs? Or can I just remove the cable and leave all the rest alone? I don't want any snap surprises though.. If I don't touch it while out, will it be fine?
Simpler to just remove all the bit so you don't have to worry about them.
It will be fine.
if you are not separating the engine and trans, you can leave that stuff alone.
| All times are GMT -8. The time now is 12:14 PM. |
