LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
Clark Griswald's Avatar
Post Silicone based grease, Warren?
Where do I buy this magical stuff?
I have called every autoparts store in town plus hardware stores. Synthetic Grease yes, lithium grease yes, moly yes, silicone grease no gots.
I got rubber spring plate bushings everywhere - ready to go together, help!
Old 08-04-2001, 01:35 PM
Early_S_Man's Avatar
Clark,
You might want to try aviation maintenance shops, scuba diving shops, or industrial bearing & seal supply stores locally ... or some of these:
http://www.aeyale.com/index.htm
http://www.escopro.com/
http://www.robertmckeown.com/product.htm
http://www.missileworks.com/motor_materials.htm
http://www.nedrhealy.com/cgi-bin/service.pl?CAT=SL
http://www.medgasexperts.com/Products/compounds.htm
http://www.warnerinstrument.com/
http://www.esticortland.com/products.asp?CategoryID=11
http://www.usairmotive.com/Aviation/Products.htm
Warren Hall
1973 911S Targa
Old 08-04-2001, 03:37 PM
Post
Thanks for the tip.
Old 08-04-2001, 04:57 PM
Post
Isn't it the same as Dielectric tune-up grease available at most automotive stores?
Borg Warner also makes it in the larger tube sizes.
Old 08-04-2001, 06:08 PM
rstoll's Avatar
Post
electronic/electrical supply.
Robert Stoll
83 SC
83 944
Old 08-04-2001, 06:14 PM
Post
Careful in the electronics supply stores, they may try to sell you silicone paste for heat-sink applications.
Old 08-04-2001, 11:50 PM
Post
I bought mine at NAPA. Your local shop should have it to. Came in a tube about the size of a toothpaste tube. It is not the same as dielectric grease.
CB
78 SC
Old 08-05-2001, 10:04 AM
Post
I have used grease like that on swimming pool repairs and maint .Try a good swim. pool supply store.
Jerry
Old 08-05-2001, 10:16 AM
Just for the record, there is very little difference between the electrical, dielecric silicone grease, Dow Corning 4, and the valve lubricating variety, Dow Corning 111 (formerly 11) ... and, no, the white, zinc oxide filled heat sink compound is not the same! Anyone on the West coast should have very little difficulty finding it!
To paraphrase Dow, on a scale of 1 to 4 for consistency, or viscosity ...
1 - Dow Corning 7 Mold Release Compound
2 - Dow Corning 4 Electrical Insulating Compound
3 - Dow Corning 111 Valve Lubricant & Sealant
4 - Dow Corning 112 High Performance Lubricant/Sealant
For those wishing to see the PDF data sheets:
http://www.neelyindustries.com/pdf/111.pdf
http://www.neelyindustries.com/pdf/112.pdf
http://www.robertmckeown.com/dc112.htm
And a comparison of several Dow silicone products:
http://www.escopro.com/compound.htm
Warren Hall
1973 911S Targa
Old 08-05-2001, 12:40 PM
