-   -   Issue after new tires (http://forums.pelicanparts.com/porsche-911-technical-forum/683864-issue-after-new-tires.html)
Wiese 06-16-2012 10:53 AM
Originally Posted by Onefastman (Post 6807108)
They are mounted properly and after a drive pressure is at 40 all around (90f here).
It looks as if the driver tie rod is slightly pinched but hard to say for sure.
On my phone but I'll try and post the pics later when I'm at my computer.
I don't think 40 psi all around is right. Most Porsche lit recommends 29 front and 34 rear. I have found that 32 front and 35 rear work best for my car and driving needs. These are cold tire pressures and will go up while driving, so always measure cold. Worth a try. Once a tire shop had put in 30 rear and 35 front for mine and the car was undriveable!
RWebb 06-16-2012 12:21 PM
too high - the above are fine; I run 32/34 or 30/34 depending
- maybe they set them all high just assuming that new tires might leak a bit for a while & corrections down would be easy to make later on
you like the shop, so call the mgr. and ask him
but do inspect carefully - something is wrong
Onefastman 06-19-2012 10:35 AM
I called the shop and he said that after new tires I probably need an alignment.
I know this is total BS so I have called the most reputable porsche shop in the area to schedule an alignment.
If it turns to be just that I will eat the $160 and move on but if something is damaged then it must have been them because I literally just drove the car home 350 miles with zero issues or problems like the ones I am having now.
I really hope nothing is wrong.
On a side note, what should I ask for alignment specs on a car that is exclusively used on the street (but aggressively so)?
Also, should I have them lower it and if so to what spec?
Joe Bob 06-19-2012 11:03 AM
Lowering the front is an easy deal, the rear is a bit more time involved unless you have adjustable spring plates. I would suggest measuring the height of the wheel arches from the ground up and then seeing how it is set now.
Depending on your budget, the current ride height and such you might want to consider corner balance, RH adjustment and alignment all at the same time. Depending on how they look, rear bushing as well.
Onefastman 06-19-2012 11:05 AM
I think I will wait to get that done as I want to re-do the suspension entirely this coming winter.
I think the rear is pretty good where it is but would like to lower the front.
How low is ROW spec and what is a reasonable amount to set it at (city driving)?
RWebb 06-19-2012 12:06 PM
get the car aligned somewhere else and get that shop to write down any thing they see like places where something was hit or crushed
then go back to shop #1 with that, and tell them you want them to pay for the alignment
KingSalmon911SC 06-19-2012 12:38 PM
+1 on RWebb's advice
Richard
Onefastman 06-21-2012 09:13 AM
Got an alignment yesterday and $165 later my issue is fixed.
So before I call them, it is completely ridiculous for new tires to throw alignment out of whack as much as it did here?
Im inclined to say yes but want to make sure before I make the call
Joe Bob 06-21-2012 09:15 AM
It depends.....are you happy or are you irked?
Go in and talk to the HNIC....work on it from there.
Oh Haha 06-21-2012 11:25 AM
I still say the first shop messed up BUT if the 2nd shop didn't notice any damage(did you ask them to look?) then I would say let it go. Maybe your tires were total garbage and WERE the reason for the problem.
Joe Bob 06-21-2012 11:26 AM
Does it track straight, is the wheel centered, are you happy?
If yes....go drive the piss outta it.....
Onefastman 06-21-2012 11:56 AM
That's what I was leaning towards.
No damage so I guess I'll just let it go.
Joe Bob 06-21-2012 12:04 PM
Send the owner a "You Suck" note......
