911 C2 1991, check engine light on, engine sounds running out of fuel...
while I am driving, the check engine light turns on, the engine sounds like it's running out of fuel and does backfire when I press the gas pedal. I have to pull over, shut off the engine and restart. After few attempts, the engine will turns back normal...
I got the DME relay and the oxygen sensor replaced, but still the same.
Anyone had this problem already? Could it be the fuel pump?
Thks,
Dan
Old 06-15-2012, 08:26 PM
RETIRED
Joe Bob's Avatar
Or the fuel filter.....probably a good idea to look at fuel pressure. When was the last time it was changed?
2012 ML350 3.0 Turbo Diesel
Old 06-15-2012, 08:33 PM
No idea... Just bought the car 4 months ago.
Old 06-15-2012, 08:39 PM
RETIRED
Joe Bob's Avatar
Are you a DIY type or do you have a mechanic? Cheap and easy replacement.
Might want to start a journal with date of maintenance of items like this if you don't have a history from the previous owner.
Oh....BTW, welcome to the board.
Might want to list your location.
Old 06-15-2012, 08:49 PM
Thks Joe! I usually am a DIY type, and have my Porsche mechanic when it's I don't have time or it's too much...
I left the car at the garage for tests, after a 30 mins road test and 20 mins on park, it never did it. I picked the Porsche up and drove it home, and did it on the way just 5 minutes after I left.
Old 06-15-2012, 09:02 PM
RETIRED
Joe Bob's Avatar
I have the same year motor in my SC.....so I know good fuel flow is a requirement.
BTW, when it dies does anything go wonky on your gauges, lights, radio or anything else electrical?
Old 06-15-2012, 09:04 PM
Scott R's Avatar
An easy route would be to buy the Durametric so you can read the check code from the computer, This should tell you whats going on.
Porsche 964
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-15-2012, 09:08 PM
The first time, it red ' oxygen sensor problem', which have been replaced. But no more fault when I try to read the code, shows 0 fault...
Old 06-15-2012, 09:17 PM
When it happens, everything else works fine, lights, radio, heater, gauges... But the rpm and the oil pressure one wich goes up and down as the engine is about to stall.
Old 06-16-2012, 06:41 AM
RETIRED
Joe Bob's Avatar
Sounds like fuel starvation.
Old 06-16-2012, 06:46 AM
I also remarked just before this problem happens, if I am waiting at the light, the RPM starts to go up a little by itself, and then the check engine light turns on with a choking session...
Old 06-16-2012, 06:51 AM
I will replace the fuel filter this week end and see if it goes better. If not, I guess my next step will be the pump...
Old 06-16-2012, 06:57 AM
RETIRED
Joe Bob's Avatar
Good luck....it's a maintenance item like an oil change. Pumps aren't cheap.....
Old 06-16-2012, 06:59 AM
Thanks! There is nothing better than a nice 911 in good shape!
I will get back with the result shortly.
Old 06-16-2012, 07:03 AM
RETIRED
Joe Bob's Avatar
Hmmmm, cheaper than I remember.....
Porsche 911 Fuel Injection (1989-98) - Page 1
Old 06-16-2012, 07:07 AM
