Ballpark cost on mid-year interior if seats already done?
Hi guys - any recent experience/ballpark for a full installed re-trim minus seats for a mid-year 911? Car is already had the interior stripped, dashboard work not required. Basically carpets and headliner and panels...
I know there are a couple well regarded shops down in North San Diego. I am in SoCal as well. Thanks!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
I just got a quote back from my guy. I was a little disappointed with the quote (higher than I was expecting). I supplied 90% of the leather and he wants just over $1500 for the RS door cards, door tops, quarter panels, quarter panel tops & rear shelf. Maybe the problem is the little bit of custom quilting?
David |
Registered Minimalist
Headliner alone is a 1500 job imho. Carpet takes finese, I'd say 2500-3k for the carpet, headliner and door panels, more customized stuff would be more.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Yikes. Looks like I will need to buy and install as much as possible.
Edit - Forgive my manners, I neglected to say thank you. I thought it, but didn’t write it. I do appreciate the responses!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 Last edited by tdskip; 09-14-2019 at 11:45 AM.. |
82 911 SC - Ancora Imparo
I agree that headliners *should* be expensive, but I have multiple local guys in FL who do quality work and will do it for under $500 if you pull and replace the glass yourself (or have someone else do it). The carpet materials start around $500 for lower quality and go up until the top end squareweave which is more like $1500. Installation can also be costly but non-squareweave isn’t super difficult to install if you want to try yourself.
Ethan 1982 911 SC - Wine Red Metallic Coupe |
Headliner is pretty easy if the windows are already removed. I did mine myself and don’t remember having any problems. I also installed my RS full carpet kit myself. Again, I don’t remember having any issues. Door panels are easy if you are just installing some from Appbiz.
Thanks guys.
My glass is out (full repaint) so hopefully that helps on the headliner. Door panells and pre-formed trim, I agree, should be pretty straight forward. Mainly the headliner that has me wanting professional help.
