SSI's & Oil Line Install Sequence
I am installing new SSI's along with the new oil lines and I installed the SSI's while th engine was out of the car. Now I am trying to install the oil lines and it looks like I should have installed the oil lines before installing the SSI's? Is there a way to connect the oil line that snakes under the tranny with the SSI's connected? Even if I can get them connected getting it tightened looks like it will be a challenge. Removing the SSI's looks like it will be the easiest but if I can avoid it I will. Any suggestions out there?
Thanks! |
oil line first, sorry
Both of them or can I get away with just removing the drivers side?
I have my 2.7 on the stand and have been looking at this as well prior to installation. I think it's easiest if you can remove both, but you MIGHT be able to get this done just pulling the driver's side.
I just pulled the drivers side and I think I got it. Anybody have the correct routing of the oil line that goes under the tranny? I assume it goes in front of the strut and heat exchanger hose?
| All times are GMT -8. The time now is 10:43 PM. |
