Turning motor by hand
My car will be up on jack stands for a while. Given how catastrophic the result of a wrong turn may do to the chain tensioner, etc. I just want to make sure I'm doing this right.
Is this what people meant by turning it CW (clockwise)? Thanks.
Old 06-19-2012, 02:04 PM
Yes the arrow shows clockwise and the engine spins that way
Ned Nyna 11
87 Carrera Targa
98 528i BMW
2004 Jetta 1.8T
Old 06-19-2012, 03:54 PM
Yes, that's the way to turn it. Do yourself a favor and always take your wrench off each time you finish doing a turn so you don't accidentally leave it in place and start the engine; I have two paint chips to prove my point!
Best,
Rutager
Rutager West
Old 06-19-2012, 04:23 PM
Now in 993 land ...
aigel's Avatar
I am curious about the pending catastrophe when turning it CCW?
G
81 SC (sold)
Old 06-19-2012, 04:27 PM
Almost Banned Once
sc_rufctr's Avatar
If you look at your fan it has to turn clockwise to draw the air in for cooling.
(There's no such thing as a stupid question)
- Peter
Almost Banned Once
sc_rufctr's Avatar
G
If you turn it CCW the timing chains may slacken causing a valve strike. You'd have to be unlucky for that to actually happen and even if it did you'd be foolish to put a lot of pressure on it if you felt some resistance.
Although a lot of foolish things have been done to our cars over the years.
- Peter
Old 06-19-2012, 04:30 PM
Thank you all for the quick responses. Much appreciated!
Old 06-19-2012, 04:39 PM
Now in 993 land ...
aigel's Avatar
The chain tensioners don't work when the chain is going the wrong direction? I realize they may not be working at 3000 rpm but hand cranking?
G
81 SC (sold)
Old 06-19-2012, 05:49 PM
Almost Banned Once
sc_rufctr's Avatar
G
You're right however I thought I had made that clear in my response using the term "may".
Either way I wouldn't do it. For instance, If you're hand cranking whilst doing a valve job and over shoot the position your going for.
It's best practice to continue clockwise until you come around to the mark again.
- Peter
Old 06-19-2012, 06:02 PM
Now in 993 land ...
aigel's Avatar
We are on the same page then - I thought i had missed something. Preferred direction is CW but you won't kill your engine if you turn CCW carefully. I have done so on several engines.
G
81 SC (sold)
Old 06-19-2012, 10:14 PM
Same experience......
G
Manually turning the crankshaft CCW won't hurt your engine provided you have tensioner doing its job. What mechanical failure or catastrophe would have resulted if you turned the engine the opposite direction manually? This is another myth people like to believe. Has anyone experienced or seen damage to the engine caused by manually turning the crankshaft the opposite way? Keep us posted.
Tony
Old 06-20-2012, 05:54 AM
