To my fellow Porsche owners, here is a question for you.
Should I change the fuel accumulator or the fuel pump? I want to change the fuel pump, but it costs about four times more. Here's a little background: 1978 Targa Aquired one month ago, third owner 65K miles No record of fuel pump replacement Fuel filter has been changed 3 times (once by me) Fuel accumulator has been changed twice Fuel pump has never been changed The problem is the engine is starved for fuel when it gets hot. I am going to test the performance difference between a full tank and a low tank. Here are some related links: I thought the fuel filter fixed the problem, but it didn't Then I thought it was a clutch problem, but it wasn't I vote for the fuel pump. What is your vote?
Stopped racing and became a drummer |
RETIRED
Try the check valve that screws into the neck of the fuel pump. 18 dollar part.
Have you done a fuel system pressure test? That will tell you if your fuel pump is bad or not.
Razor...in my run thru this same problem I replaced the fuel filter...then the accumulator..then the check valve...finally we checked the pressures...it was difficult because mine only happened when really warmed up. I had told the shop guys this but I think they only got the engine/engine oil temp up...I think the fuel pump itself must get a little warm because my problem only occured after 20 minutes or so of driving in 60-70 deegree ambient temp) Anyhow the fuel pump was replaced and it has been purr-fect ever since!
Richard Lane 1978 911SC 1973 "Clean" RS clone |
Senior Member
Richard had a good result from replacing the FP, but I strongly recommend testing first. The FP should be capable of achieving a certain fuel pressure, and also it should be able to move a specific volume of fuel in one minute. If it does these two things, then it is not your problem.
I have replaced many, many parts in my day that did not need replacing. This happens when I GUESS at what is wrong. Fuel pumps are among the parts I have replaced needlessly. I have found plugged (usually with rust) and bent/kinked fuel lines to be a problem more often than faulty fuel parts.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Good point Superman..this was my first significant problem with my car and I needlessly replaced a bunch of parts due to guesswork and faulty logic. I would have been better getting the pressures and volume checked first (but hey it was a good learning experience and I learned a lot about my fuel and ignition systems!!
RETIRED
Hot start problems after a long drive on two of my 3.0 CIS motors BOTH turned out to be check valve problems.....I diagnosed it by checking fuel pressure after a long drive......
Fuel pressure bled off immediately.....not as designed. |
On the 1978 they call the check valve a fitting. The part doesn't look like a check valve. It looks like it takes the fuel and splits it into two directions.
How is changing this going to solve the problem?
The item in red is the check valve. It's about $16. Of all of the components that help to hold residual pressure it's the cheapest.
http://www.pelicanparts.com/catalog/images/fuel_injection/new_images/fi_fuelsystem_2-1c34a.jpg
Bill Krause We don't wonder where we're going or remember where we've been. |
Yes. This is the part that I have at my house (ordered it about 1 week ago). But it's not a check valve the way I know a check valve. It's more like a flow splitter. I will change it, but I don't see how this will fix the problem.
Also, note that it's not called a check valve on the 1977-1979 models. It is called a connection. Could it be that this part became a check valve on 1980-1989 model 911 cars?
Stopped racing and became a drummer Last edited by RazorRacer; 05-16-2002 at 08:00 PM.. |
