Nobody
bob tilton's Avatar
valve clearance spec for 2.7
i am in need of the following spec for a buddy with a '70T/2.7 transplant and a failing internet connection.
from wayne's book:
"On the 911SC type 930/10 motor, this value of intake valve stroke in overlapping TDC with 0.1mm valve clearance must be set between 0.9mm and 1.1mm. To find out this value for your particular motor and cams, check the Porsche Factory Spec Book for your year car."
i am looking for the valve inlet lift. tia.
bob
Old 05-15-2002, 08:39 PM
Early_S_Man's Avatar
Porsche Crest
Which 2.7 engine is it ... type number??? 911/xx???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-15-2002, 11:15 PM
