-   -   911SC Poor Running & Distributor Signal Phasing Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/684398-911sc-poor-running-distributor-signal-phasing-problem.html)
Lorenfb 06-19-2012 06:49 AM
Over the years a numbers of Porsche mechanics have experienced poor running
conditions at RPMs below 3000 and incorrect distributor alignments relative to
Z1 on the damper pulley on 911SC engines. This usually results when the distributor
has been rebuilt or the green wire replaced.
The problem is caused by the incorrect polarity (phasing) of the distributor signal to
the CDI unit. Since the unit triggers the spark on the negative going edge of the
distributor signal, that edge must go negative in a short time relative to the spark
timing. If the signal polarity is incorrect and the triggering signal changes too
slowly, the timing will be incorrect relative to the low and high RPMs. The problem
is easily corrected by just reversing the pins of the green wire.
The ideal method for determining the correct polarity is by using an oscilloscope.
The negative going edge must be the faster voltage changing edge of the signal.
One can also possibly determine the problem using a timing light by noticing how
stable the timing advances as the RPMs increase. Once the signal has the correct
polarity, the static timing relative to Z1 and the dynamic timing (timing light) will
be correct and the engine will run smoothly and rev very responsively as the RPMs
are increased.
Therefore, when experiencing a poor running 911SC, one should always check
the distributor signal phasing (polarity).
Mitch1 05-29-2014 03:54 PM
Old thread post, I know. Bought a new distributor green wire for my rebuild, with timmy2 ' s advice. Turns out, one I got was pinned wrong. Polarity reversed. Same exact symptoms as stated above. Thanks Loren.
