Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Send a message via AIM to tmblackflag Send a message via Yahoo to tmblackflag
knocking/rattle from alt housing, new alt didnt fix, have video
Hello,
i recently replaced my alternator due to a knocking/rattling sound coming from the housing. The sound did not go away. I took a few videos of the sound with and without the fan belt attached.
A little background on the knocking sound. When i took the alternator out over the weekend I found a decent sized crack in the alternator housing. I had it welded up by what i believe to be a competent magnesium welder. You can see pictures of the before cracks here. went to replace alternator and housing is cracked
Unfortunately i didnt take an after picture before i put it back in.
1st is just checking fan belt tension. Is this about right? 20120618_185902.mp4 - YouTube
2nd gets you a nice listen in on the rattling/knocking sound with the fan belt attached 20120618 190004 - YouTube
3rd is with the fan belt disconnected. Sound is lower but i can definitely still hear the rattle. 20120618 192112 - YouTube
any help diagnosing the sound is appreciated. thanks
1986 3.2 Meteor Metallic Grey
Old 06-19-2012, 07:47 AM
a knock with no belt kinda makes you think it's internal, doesn't it?
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 06-19-2012, 08:26 AM
The distributor maybe ?
Also listen to the chain housings, maybe a tensioner starting to fail ie; not holding constant presure on the chain.
Dosent sound like much to worry about on the video, but i understand your concerns, do some listening with a long screwdriver against the cases and your ear, be carefull, and dont wear a tie while doing it!
Hope this helps.
Anthony.
Old 06-19-2012, 08:33 AM
loose crank gears, worn intermediate aluminum gear backlash, distributor worn out, tensioners failing, broken chain ramp, piston slap, wrist pin bushings worn, rod bearing, loose crank pulley, valve tick.....
Old 06-19-2012, 09:09 AM
Is that fan belt tension proper? I thought maybe it was one shim too tight.
And John, yikes! I'm due for a tuneup and valve adjustment. We'll see how it sounds after that.
Old 06-19-2012, 09:24 AM
Nothing serious then John!
Realy hope you get to the bottom of it.
A...
Old 06-19-2012, 09:25 AM
Can anyone confirm if my belt tension is correct (see first video)
thanks!
Old 06-19-2012, 05:54 PM
Send a message via Skype™ to Porboynz
Tension looks good to me but difficult to tell how hard you are pressing, should take a fairly firm press for that much movement imo. Re the noise, lets add exhaust leak or broken head stud to the list just to be sure you never have a restful nights sleep ever again. Probably a wild valve gap.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-19-2012, 09:56 PM
Belt might be one shim too tight, if it's a new belt it'll stretch just a bit and you'll be fine. Or, add another shim inside and see if it's too loose.
Old 06-20-2012, 08:05 AM
76 911S Targa
Was the noise present before you repaired the fan housing? If not, then I suspect there is interference between the crank pulley and the housing. What else could it be if the fan and alternator are not turning? If the noise was present before your repair and you attributed it to the cracked housing, then the problem is elsewhere in the engine. A simple diagnostic would be to remove the fan housing and alternator and run the engine for a short period without them installed and see if the noise persists. Good luck!
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Trombone Oil Cooler, Turbo Tie Rods.
Old 06-20-2012, 09:06 AM
The noise was present before the alt was replaced and the housing repaired.
One more important note. On a cold start there is no noise @ that 1100rpm for the first 45 seconds or so. Once the car settles into it its 900rpm idle (car has a chip) that when the noise appears. I do find myself stalling out occasionally from stop to start in first gear. But the car idles fine at 900rpm so i don't think its a vacuum issue.
Old 06-21-2012, 09:13 PM
