Somatic Negative Optimist
Gunter's Avatar
Question Temperature range 3.2
My friend replaced a 1977-2.7 with a 3.2 and noticed a higher temperature range. He has an extra oil cooler in the front fender. With the 2.7, the gauge showed 170-180 but with the 3.2, it runs between 180-205. Even up to 210 on a hill climb. This is B.C. Canada on cool days. He is wondering what happens on really hot days. What is the normal operating range for a 3.2? Do they run hotter than 2.7's? Thanks anyone.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-14-2002, 11:13 AM
AES AES is offline
The stock external cooler on a 2.7 is smaller and less efficient than the stock 3.2 external cooler. Higher operating temps are to be expected. If the temps get much above ~220F I would get a bigger fender cooler.
Old 05-14-2002, 11:17 AM
Chuck Moreland's Avatar
The correct operating range for the 3.2 is the same as the 2.7.
The 3.2 produces more heat than a 2.7. The factory made provision for this by making an external fender mount oil cooler standard on the 3.2 cars. This has come to be known as the Carrera oil cooler.
Although some 2.7s came with fender coolers, most did not. I assume your friend's is lacking this.
Your friend would do well to add the fender mount cooler.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-14-2002, 11:20 AM
