Odometer jumps 10k miles?!
Did a search but can't seem to find this same issue. I just realized at some point in the last few days my car's (88 Carrera) odometer has suddenly leapt ahead by about 10,000 miles! Anyone ever seen this before? It appears to be working fine now and registering what seems to be the correct miles actually driven.
Tachometer and speedometer have been working as designed and I'd have noticed anything odd with them. I did have an issue about a year ago with a bad speedo gear which I replaced. I also found out back then that I have a 4 magnetic rotor for the sensor and not the more common 8 magnets. I don't think that is the issue since it was working fine otherwise. Any ideas welcome,
Buck '88 Coupe, '87 Cab sold '88 535i sold (really miss it) '07 A4 DD Warren Hall, gone but not forgotten |
Not sure why that happens but last month on a long drive the odometer on my 87 jumped 100,000 miles thank god I am not trying to sell it. I hope someone answers the thread and clears up what is going on.
88 930 Black Slantnose Sold and on the hunt again 04 Cayenne 87 930 Blue/Gray/Black/Purple depends on the lighting Still cant believe it but Sold 81 911 Sold , 85 911 Sold, 80 911 Sold, 85 928 Sold Miss them all |
OK...doing the mental math again, it was more like a 20,000 mile jump...from around 185,000 to 206,000. Still makes no sense. I could see a 100k jump due to one of the gears moving, but 20k?
Just to confirm, you are now in 2012, what year were you in last time you checked the odo? :-)
You didn't just install a flux capacitor did you? |
Talk about turbo lag.......
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Wider is Better
Wow!!! You drive fast!
Wider is Better |
I keep all the bottles of oil I add and write down the mileage to keep track of the oil usage post rebuild. I noticed that I last added a quart at about in mid May with mileage of about 186,000 miles and now I'm at 206,000!!! I barely drive 800 miles a month...at most.
Somethings wrong...
Do you have a teenage son?
or use valet parking?
"I broke it daddy" My two year old daughter Grace after dropping a Christmas bulb. |
No kids, no valets ever, just two Welsh Corgies and they can't see over the bottom of the window...and I hide the keys from them.
Is is possible to "correct" an odometer by 20,000 miles and not damage it? It's not really an issue since I am keeping the car but it's bugging me that its wrong. I had it apart about a year ago to replace the gear and that was fairly painless but I obviously did nothing with the mileage.
I'd suspect a broken or jammed gear within the gauge.
talk to north hollywood speedometer. They will fix it and reset it. Probably $100. They'll restore the gauge for a little more. They did a great job for me. Doug
1971 RSR - interpretation |
HTH, Chuck.H '89 TurboLookTarga, 338k miles |
Smoove1010
I'm glad to read that I'm not the only one - no valet, no Bueller... In the space of one tank of gas my odometer went from 99K and change to 299K and change! My candidate for full resto just became a parts car! Seriously - is correcting an odo a DIY job, or is this best left to the pros (who can update weak gears, etc., while they are at it?) Lastly, this doesn't see logical - how could this happen?
THX, GK |
OK...thanks for the recommendations but I've rebuilt my engine down to the crank...do I really need to send my odometer to NHS to correct the mileage? I may just take the thing apart again and, worst case scenario, send it to someone to change the mileage.
Don't know. but if you try it, post back and let us know how you got on - I need to add 231,000 miles to the instrument in the car now.
'77 S with '78 930 power and a few other things. |
I wonder if any shop will alter the ODO readings?
They altered mine - semi reluctantly but I wanted it accurate - when the odo broke, I roughly kept track of my miles and had them add them into the number, which they did.
It's not hard to change the mileage. Toughest part is prying the lip to open the speedometer up and recrimp it neatly. When I put the '86 3.2 engine and tranny in my 1973.5, I changed the broken gear on the electronic speedometer I bought, and while I was at it set the mileage to match the original mechanical speedo. I like to keep track of the actual mileage on the car, I even notified DMV of the speedometer swap when I registered it.
Ed 1973.5 T |
Drive backwards or a while
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
We've gone Plaid!
(from the movie Spaceballs) Take care! Last edited by FrenchToast; 08-22-2012 at 11:01 AM.. |
