vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
SC Not Starting - could it be ....
After reinstalling my engine after having it out for the past 4 months I tried starting it tonight. It just turns over and it appears like it is not getting gas. Could it be one of the following:
- Oxygen sensor not connected?
- the 2 wires in the tunnel (by the shift linkage) not connected?
- new fuel filter not getting gas?
Any other ideas? I removed the engine and did a pretty comprehensive refresh. I suspect it is something basic.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-21-2012, 08:21 PM
Check to see if you have spark! Do you still have FI?? If so check for power to the Ign Module (CD Box) and the coil while someone trys to start it! My CD Box went out and I had the same symptom! Also check your ground strap!
Old 06-21-2012, 08:30 PM
KeithC
Have you checked your fuel pump relay? I had exactly the same problem.
Old 06-21-2012, 09:33 PM
Scott R's Avatar
Are you able to prime the injectors? Do they spray?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-21-2012, 09:34 PM
vesnyder's Avatar
Do I have to prime the injectors? How do you do that? I do not think I am getting gas. Should I hear the fuel pump when I turn the ignition on? I do not hear anything.
Vance
Old 06-22-2012, 03:41 AM
T77911S's Avatar
you need to check for spark first! that is an easy check and cuts your problems in half.
if you have no spark:
turn the key on
raise the sensor plate and listen for a rather loud "whine" or squeal coming from the injection system.
now try to start it.
if no noise, your FP is not running
let us know the result
perhaps a little background:
why was it out?
what did you do to the engine while out?
did you do anything else to the car while it was out?
how did it run/start before you took it out?
do you have presure gauges and have you checked fuel pressure?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-22-2012, 04:27 AM
schumicat's Avatar
it isn't the first 2. it is either lack of fuel or lack of spark.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-22-2012, 06:01 AM
vesnyder's Avatar
To provide some background, the car was running fine when I decided to pull the engine this Winter. I ended up doing more than I had planned but the primary efforts were around the standard oil leaks and new SSI's/muffler. Also put in a new clutch while I was in there.
Concluded that I am not getting a spark! What is the most logical candidate?
Vance
Old 06-22-2012, 01:43 PM
Can you hear the CDI Box wineing when the key is turned on? Check for power at the coil when the key is on!
Old 06-22-2012, 04:42 PM
