Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Rear targa glass install
I installed my targa glass and missed a 2 inch section of the seal towards the middle at the back(deck lid area). I can't get anything in there to pull it over because of how tight the seal is against the flange with the rest in place. The area is accessible with the interior out.
I need some tool recommendations please.
Allen
Old 06-23-2012, 04:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
DDK - Die Deutschen Klassiker • View topic - Never mind the Higgs Boson .....
Might work for a targa
Regards
Mike
RS #1551
67S
Old 06-23-2012, 04:33 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Cool info, wrong problem though. I need something to grab and pull the seal over the metal flange on the car. The trim piece isn't the issue. I can get at the area and managed to get under an area already in place, but it was with a flattened coat hanger which is too weak to pull the seal over the flange.
Thanks, Allen
Old 06-24-2012, 01:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
mcaterino's Avatar
I had a similar problem with the rear window seal. A heavy nail with the last 8mm or so hammered flat, bent at a 90 degree angle and with the point blunted did the trick. Silicon grease it and it should slide along pulling the last bit of seal over the frame.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 06-24-2012, 06:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Push the window out and strat over. With that little bit left the window is not all the way sealed so you can reverse install the window to remove it with out damaging the seal. It won't be easy but YOU CAN DO IT.
Old 06-24-2012, 07:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
80-911SC's Avatar
if all else fails .. take it out .. re rope it and start again ..
Old 06-24-2012, 11:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
