-   -   Stop Running (http://forums.pelicanparts.com/porsche-911-technical-forum/685298-stop-running.html)
tpweiss9953 06-24-2012 04:35 AM
Stop Running
Trying to take care of a few problems with my new 911...
Sometimes when i turn the car off it still trys to run for a second.
Could this be a bad distributor cap?
Hopefully it is. Have a new cap, rotor, wires, plugs to put in.
twistoffat 06-24-2012 04:47 AM
Could be a faulty DME Relay or leaky injectors. When you turn is off its still getting fuel.
Do a search on "Dieseling" and you should find plenty of info
Grady Clay 06-24-2012 05:38 AM
twistoffat is ‘right on'.
Some tests you can do are to replace the spark plugs with 1-step ‘colder’ heat range.
Another is to use a tank of 100-octane (unleaded) race fuel.
Post images of your sparkplugs.
Best,
Grady
tpweiss9953 06-24-2012 06:46 AM
I believe the injectors were just recently cleaned. Car is going in this Tuesday for valve adj/gaskets/plugs. The plugs I purchased are Bosch WR7DC+ (Bosch Super Plus plug with copper core and yttrium added) Part number 999-170-156-90-M14.
Will order a DME and check that first. I will also post pics later this week of the plugs.
Race fuel, really?
