Distributor rotor
Hi all,
I have a ROW 82 SC Targa. I have converted my car to run on an aftermarket ECU. The tuner says that the contact area on the rotor arm in the distributor is not wide enough to allow him to advance the timing enough at low RPM. The contact area on my SC rotor is 11mm, looking at a carrera rotor, this seems to be larger, but will a carrera rotor fit in an SC distributor? Regards |
