Engine bay rust. Is that bad?
Was inspecting my 72 at the paint shop. Looks great but we we're replacing the engine hood shock and noticed surface rust behind the motor, against the bay wall. My interior guy wasn't concerned. I thought it was an odd place for rust. A few spots flaked pretty good.
Should I worry? I was gonna wire brush and spray with rust prevention paint.
Old 06-28-2012, 12:29 PM
advtracing's Avatar
check the parcel tray inside
"Funding my obsession one nut at a time"
Old 06-28-2012, 12:58 PM
Vereeken's Avatar
Not so odd. You can see on Pelican a number of restoration projects with the rear parcel shelft rusted out.
From my experience the cause is the rear window rubber at the lower side at the corners. it works its way down. The sealing is not 100%.
New sealing products have improved the situation, but how often does a rear window get replaced.
Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 06-28-2012, 01:30 PM
RETIRED
Joe Bob's Avatar
Poke around with a scraper and see how deep it is. Weld any holes, sand and POR 15 the hell out it.
2012 ML350 3.0 Turbo Diesel
Old 06-28-2012, 02:03 PM
Eschews Obfuscation
dhagood's Avatar
all rust is bad. some rust is worse. i would also look at the parcel shelf and would additionally look at both the rear seat pans and torque tube for the rear suspension (both inside and outside) to see if there was additional rust at those locations. i would also strongly consider replacing both rear window and windshield seals.
yes, this is a lot of work and is mostly likely expensive if you don't do it yourself.
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 06-28-2012, 03:03 PM
